Converting my sailboat to all electric (other than sails obviously) and plan on using a 48v forklift motor, probably around 2kw, then use a 48v-12v dc for other random house items, and an mppt 48v solar panel charge controller.
Unfortunately the name of the volt is volt, and searching turns up every page with the word volt or voltage. anyone have any good threads on re purposing these batteries? I would run the 2 24v packs in series then in parallel with the 2 48v packs. Then charged by 2x 200w solar panels, a regen prop (seperate pwm controller) and possibly small wind turbine.
