1 - 2 of 2 Posts
Discussion Starter #1
Has anyone tried using a voltage multiplier, boost regulator or charge pump to get to the high voltages required to run some industrial motors?
Mine requires a nominal of 600V, and I'm working on a boost regulator that can boost from a 120VDC battery pack to a voltage of 600 to 700 volts.
Just remember that watts out will be just slightly less than watts input. In other words, you will need say 300 amps X 120 volts to get say 60 amps at 600 volts
1 - 2 of 2 Posts
