A 300kwhr battery should do the trick
But i was looking for the probable V and I values to consider for derivations to determine the number of cells in series and parallel.A 300kwhr battery should do the trick
Key point Duncan is making here 40Kwhr will be great for your range at moderate speeds 50-60mph. If you want your range at 150mph then you probably will need that 300Kwhr pack. I think the ideal target is somewhere in between. But 40Kwh is a common target, usually due to budget, weight and availability constraints.So you need about 40 Kwhrs for your range
170 Hp is 127 Kw - a 40 Kwhr battery should be capable of delivering that for a short period
If the zombie 222 can almost hit 200 a beetle can go 150. Don't let anyone kill your dreams. Just over build it and spend some $$ on safety bits too.I do hope you don't mean an original beetle!You will most likely die if you try to take an original beetle to 150mph!!
Even aside from the fact that the original Mustang was designed three decades after the original Beetle, they have nothing in common, and the Mustang is fundamentally much more sound for high-speed operation.If the zombie 222 can almost hit 200 a beetle can go 150.
True. And true.Even aside from the fact that the original Mustang was designed three decades after the original Beetle, they have nothing in common, and the Mustang is fundamentally much more sound for high-speed operation.
Still, even a old Beetle chassis could go 150 mph with an adequate degree of stability, with a bunch of work. After all, an old Porsche is nothing but a slightly rebodied Beetle.
I'm just curious, not judging.![]()
