1 - 4 of 4 Posts
Pretty good video...
It sure seems like the EV "LS" motor would just be a VW/Ford/Chevy motor with an adapter plate in place of a gearbox (or a modified gearbox??)...The scene is begging for an OEM motor that will work in RWD conversions, and the Leaf motor didn't seem to get much tractoin over the Hyper9/AC51 (much to my surprise).
I'm surprised there aren't off-the-shelf plates like this for Tesla motors yet...Hopefully the volume coming from the latest OEM BEVs will inspire someone to produce a conversion in quantity.
It sure seems like the EV "LS" motor would just be a VW/Ford/Chevy motor with an adapter plate in place of a gearbox (or a modified gearbox??)...The scene is begging for an OEM motor that will work in RWD conversions...
In the ubiquitous LS swap, the original transmission or a transmission better-suited to the LS engine is used; similarly, in an electric motor swap a transmission is typically needed to use the full capability of the motor. It can be just a fixed-ratio gearbox, and ideally the motor plus gearbox would fit in the space originally occupied by a transmission, but that can be a tight fit.
The EV West "crate motor" is an example of this approach (complete with fixed-ratio gearbox). I assume that it uses a Tesla Model S motor simply because they're available and familiar to the suppliers involved.
Heh, yeah...I'm looking for a setup that's closer to $3k than $30k.
Figuring a Tesla SDU runs about $5k these days and a TorqueBox well under $5k...I just don't know where EV West got $20k worth of machining...
I'm not questioning EV West's costing method, but I'm also not suggesting buying that unit. ;) It is an illustration of the approach, and starting with a motor that detaches from the transaxle cleanly (unlike the Model S induction motors which use one aluminum casting as both a transaxle side housing and a motor end housing) would be easier.
1 - 4 of 4 Posts
