I need to mount my Kostov 10" on the VW Bus/Beetle tranny. The transmission drive shaft has about two inches that stick out beyond the geared part. Should I cut that off?
Cutting it would move the motor two inches closer to the gear box and make the coupler 2 inches shorter as well, but It feels kind of "wrong". What did you guys do?
Also, with the motor hanging off the back of the transmission (just like the old ICE), should I add another motor mount at the rear, or is mounting it on the gear box enough?
Thanks,
Matt
Thanks,
Matt
