Hi to all!
This is my first conversion. A lightweight "mid-sized" Volkswagen Polo/Derby.
This one is Polo but the saloon or sedan version is called in some countries Derby.
I have had this car for almost 5 years and it has been a joy.
It takes 6l/100km or 40mpg regardless whether driving in a city or a freeway. Begs for the 5th gear in 120km/h speed.
I am not quite the engineer myself. I can barely weld, but that's why there's friends and machinists.
More info about the car, in short, VW Polo -89, 760kg, 1675lbs, 1.3l, 40kw (55hv), 96nm at somewhere in 3000rpm
ermm.. 70 ft*lbf?
My goals are:
Some things concern me!
Polo's transmission is so tiny that even a K9 won't fit without a little machining. It hits the drive shaft
I ordered the fan, forced air cooling, with K9 and i fear that it hits engine bay wall. Damn.
The motor and the transmission are currently under work by machinist, who will do the coupler and the adapter plate. Has to be clutchless due to limited space...
Currently Polo is waiting for a new paintwork. I have some pictures jeij!
Okay, this was my second post. Feel free to tell what you think and to give advice.
Tomi
My goals are:
- Performance better or the same
- Top speed should be atleast 120km/h or 75mph, depends on gear ratios, which I can't change
- 100km/charge, 60miles per charge (more the merrier)
- Budget was at first 5k€ but now it's more like 10k€ and so on
Depends much on batteries..
- I have bought already Kostov 9' 144v Series DC motor and TcCharger 144v (108v-216v) DC-DC converter. Other parts that I'm almost certain of are Soliton Junior, minibms, TcCharger charger 144v and a lot of batteries, atleast 144v/60ah Sinopoly (B) cells. Battery is still a bit open question.
To achieve 100km per charge I should use the 100ah Sinopoly cells or parallel 90 60ah (B) cells to get 144v/120ah.
This means -> 760kg-(585kg+ Kostov 45kg+ Soliton Jr. 7kg) = 123kg to fill with batteries and etc. GWL of polo is 1130kg. For example 45x100ah Sinopoly = 3.1kgx45 = 140kg. I can remove the middle back seat though which adds 70kg to play with. Can you imagine this is a 5 seater car?the Polo has a "ready for conversion" weight of 585kg.
Tomi
