I'm spending a lot more time on this project, and things are still moving slowly! I attempted to fit an iBooster in place of the master brake cylinder, but it doesn't fit properly, header tank is too high, and control electronics block the heater pipe, so I've decided to keep the original brake booster, and add a vacuum pump and container. Any advice on vacuum pumps, reservoirs, sensors etc appreciated!
I've also removed the pedal assembly, the clutch will be removed and the brake re-installed. The accelerator is hanging by its cable for now. I'll get that out shortly to work out how to wire it to the Tesla SDU.
I've also started work on designing the mounts for the battery box. This turns out to be fairly simple, using angle. I also need to fabricate the final engine mount, currently hanging by a strap!
This week has involved a LOT of measuring, offering things up, and design, so progress seems slow. One key decision that has been made is the layout of the batteries. I will be be using only 15 of my 18 modules, giving me a 80S3P configuration. This allows the whole battery pack to sit above and in front of the drive unit in a single block, 5 modules across, 3 front to back. They will be pressed up against the partition to improve weight distribution as much as possible. Putting battery modules in the front, or fuel tank space is not practical.
