5
Today was a big day of low voltage wiring! I've made up and installed low voltage looms for each component and brought them all to a single location:
- VCU (charge controller)
- Gear Selector
- Small Drive Unit
- Charger / DC-DC Converter
- The existing OEM engine loom (power, throttle, warning lights, etc)
- Vacuum pump
With all that in one place, I am now ready to splice everything together as needed. The Dutch 12 pin plug for the battery box really is a joy to assemble. Highly recommended!
I made some last minute changes to my wiring plans to ensure that the CAN bus meets the standards. In particular, making sure that stubs are kept below 300mm. Because my battery box contains a "dead end" on the CAN bus, and because the SDU contains a termination resistor, I decided to start the bus in the battery box, run it all the way to the front of the car to the VCU under the dash, then all the way back to the rear, to the charger (there are 2 CAN pairs in the charger loom) and then finally into the SDU.
I also took the opportunity to give the car 12V for the first time in a while. I have an array of warning lights for the brakes, ABS, and airbags, but hopefully those will be happy once the brakes and seatbelts are reconnected. I've bought an OpCom OBD2 cable to reset those fault codes as needed. Apart from that, everything still seems to work as it should, and power is available where I need it to be. I've tested the vacuum pump, which is a little loud as expected, but only runs during braking to replenish the vacuum, so not too annoying.
