Hi,
Wanted Affordable 96V Sepex Controller for a Zenn NEV.
I am using two Chevy Volt 22S modules (we trimmed two cells off of Chevy Volt 12S modules connected in series = 24s x 2, to get 22S) in parallel (90AH) into my Zenn NEV.
That configuration should have (22 x 4.1v x 90Ah) 90.2 x 90 = 80.18kWh, which should give a range of about 50 miles. But 84 volts is all we can get out of the battery pack before we get an over voltage error from the factory controller (a Sepex GE IC3645SR7A353E1).
Which means that we can only charge the cells to 3.81 volts, which is limiting the range to about 20 miles.
So I need to find another sepex controller that can handle the higher voltage.
If it's simple to install, and affordable it will be perfect!
