I'm building my first EV conversion and picked up a pair of vehicles from a local university auction. They are 72V dry cell setups with HPEVS AC-30's. I'm not sure that I will use either vehicle but one is a pickup truck which could be handy to have around the shop.
I was going to buy 6 new batteries but at $350/piece I don't want to invest that much in something I know I won't use long-term.
I'm looking for a used 72Vpack of either AGM or LiPo to start get my truck back on the road and possibly put it in my old 46 willys. If you have something within driving distance of SC, please PM or email me benji at walvoord dot net.
Thank you
You might consider looking into Chevy Volt lithium batteries. They are pretty awesome. Search on Ebay - you can find smaller, individual units which are about 2kWh @ ~ 48v nominal @ 47ah (50v max charge level). You can also get an entire pack - 16kWh - very reasonable if you look around (ebay!). People also sometimes sell them here.
I have a setup in my first EV where I am using two of these 2kWh modules in series - 100v @ 47ah (4kWh block). Then I put 6 of these 4kWh blocks in parallel, so I have a 24kWh battery moving my little Bradley... and the range is really good.
I wonder if the max voltage on your controllers is near 100v? If so this would be an excellent option - even just 2x 4kWh blocks (in parallel) as described above.
btw one of the nice things about these Chevy Volt batteries - the physical dimensions - the footprint of each 2kWh module is about 9" x 9". So if you have a rack that was built for, say, 4 golf cart batteries, most likely the dimensions of the rack are about 11 (the length of one golf cart is 10.5) x 28 or 29" (the width of one golf cart is 7")... i.e. the rack accomodates 4 golf carts stacked side by side - 4x7 = 28". So anyways, this would fit 3x 2kWh
Volt Units (3x9 = 27"). If you happen to have TWO such racks (accomodating 8 golf carts) - you could then fit a total of 6x 2kWh Chevy Volt units. Wire them however you want... such as 2s and 3p... =)
Cheers!
-Ocean
