1 - 5 of 5 Posts
Whining bearings,, as one member pointed out several years ago would happen in time.
And i know what happens when they come apart,,or worse seize.
So if i could get a new one,,i could fix my old one,,use other bearings that are more suitable 4 the job.
Located Norway. But would travel Global if needed.:)
You are right. But i was planning using the local garage 4 the Gear swap.If i could source a resonable Box.And meanwhile rebuild the other as a backup.
This car has been on an airport from new,,so alot Fwd-Rwd.And something about those bearings,,not support Axial movement,,. There is a thread discussing this.
1 - 5 of 5 Posts
