1 - 4 of 4 Posts
Discussion Starter #1
Hello,
I am looking for the Nissan Leaf BMS 2013 and later.
I have a 2013 Nissan Leaf battery pack, which I am using to reverse engineer the serial protocol between the microcontroller and the balancing ICs, so I can reconfigure the pack for use in my Solectria E10, and still use the BMS.
I recently purchased a 2013 BMS on eBay and it was different than the one that came with my battery pack, so I suspect it was actually an earlier version...
The BMS I am looking for has:
Plastic backer, not metal.
One gray and black connector, not all white connectors:
http://www.wolftronix.com/E10_LithiumUpgrade/images/IMG_5574.jpg
Uses D15120 balancing ICs not, the D15110 balancing ICs.
The serial protocol is different between the two types.
Thanks,
Wolf
1 - 4 of 4 Posts
