Hello, I'm starting a conversion and have two warp 9 motors.
1)What are the available adapters for warp 9 for coupling dual motors?
So far I only see 'Dual Motor Siamese Adapter' from ev west. Other than getting an adapter machined are there any other adapter produced that can be bought?
2)Since I already have two warp 9 motors. I'm planning to run direct drive to the drive shaft. Will it be okay to use a keyed yoke or will I need to swap the motor connected to the driveshaft to the transwarp motor?
