You might be able to do better but not by much. Pricing seems pretty right on. I have one of the new KDHD 800 amp controller but have not use it yet. Soon. If you go with the Kelly you will need a large heat sink and you will need a fan attached too. Do not skimp on the heat sink. It needs good deep fins and a good thick flat surface to mount to. Use good quality thermal compound between the controller and sink. Not too thick. Mount tight. If you can afford a better controller then get it. Soliton1 will fit your needs. Synkromotive will fit your needs. I will check how well the Kelly works here real soon. Pulling off the Synkro in a couple weeks. It will be used in another conversion.
Pete
Hunt for good used Warp9" motors. You could check out if the kit includes the newest Warp9. But I would not be surprised if they say yes but give you an older one. They do have a nice new Warp9 with a bunch of new goodies. I don't think the price has changed from the old one to the new one. You may do better if you buy your parts separate than in a kit. I put mine together myself.
Pete
Pete
Pete
