Welcome.
What will determine your range is the pack, top speed, how aero dynamic your car is, the status of the brakes and transmission etc. The efficiency of an AC versus DC system are pretty much the same so a dragging brake or rotten aero dynamics will affect your range tenfold more.
Regen will only make a noticeable difference if you live in a hilly place or do a lot of stop and go, then regen might (with emphasis on might) improve your range up to 5-10% or so, but you'll be paying something like trice the money for the same power (or, of course, pay the same but get a lot less power). If you're mainly cruising regen will do no difference what so ever for you.
And even if you might actually benefit from regen you'll probably save money on going DC anyway and add a few more cells to the pack to compensate for the lack of regen.
Bullshit.
Weight and storage seems ok, but it's not very aero dynamic, is it? Combine that with your desired range and top speed and you'll need a hell of a pack. You might want to consider going slower or make shorter trips...
