Hello Gulabrao,
The ampere-hour rating of a battery is the measure on how many amperes it
can draw in a specific amount of time. The standard rating which is choose
by battery companies, is how long it takes to discharge a battery to 0%
State OF Charge (SOC) or is the same as 100% Depth Of Discharge (DOD).
For example:
A battery that can be discharge at 5 amperes at 20 hours, this is a 5 Amps x
20 hrs = 100 AH battery.
A reserved minute rating at 20 hours would be 20 hrs x 60 mins = 1200
reserved minutes.
Now as you increase the ampere draw of the battery, the ampere-hour rating
of the battery decreases. If you increase the the ampere load of the battery
to about 20 amperes, it may only deliver 20 amps for 4 hours, which is a
actual capacity of 80 ampere-hours.
You can convert the reserved minutes that is list for a battery. For
example, a battery with a 100 AH rating with a listed Reserved Minutes of
180 minutes for a 25 amp draw would be about:
180 min / 60 = 3 hrs
3hr x 25 amps = 75 amp-hrs
So you see, when the ampere draw of a battery goes up, you have less
ampere-hour available.
The average ampere draw for a EV is about 75 battery amperes. The reserved
minutes listed for a 100 Ah battery is about 60 minutes at 75 amps which is
about one third the time at 25 reserved minutes.
My Trojan T-145's is a 260 AH at a 20 hr rate battery with a 145 reserved
minutes at 75 amps. The actual ampere-hour would be:
145 mins / 60 = 2.41 hrs
2.41 hrs x 75 amps = 181.25 AH
It is best not to discharge a Pb-Acid battery below 50% DOD, so the maximum
ampere-hour draw out the battery would be 90 AH. For a long life I normally
charge at at 120 ampere-hour remaining in the battery or about 25 DOD%.
Roland
----- Original Message -----
[email protected]>
To: <
[email protected]>
Sent: Monday, July 30, 2007 12:12 AM
Subject: what does Ah or ampere hour signify
> Hello All
> What does Ampere hour signify ?
> does a higher ah rating equals more range , what is the ideal Ah
> rating for an EV
> Thanks
> Gulabrao
