Hi James,
In your design, 2/0 welding cable is more than fine for the feed cables, 4/0 can be used for the motor cables. (the motor cables can see higher current through them than the battery cable because the voltage to the motor is varied by the controller, except at full throttle) We have used 1/0 cable throughout without any heating at all, even in liquid tite conduit. Generally you want to use the large cable just to limit voltage drop through the cable for the short periods of time at high current, as heating is not an issue.
I would use welding cable, it is much more flexible with a lot of finer strands. I would also just crimp them with a correct sized crimper.
We have tried to get the NEC and cable organizations to give a recommendation for cable size for EV's , but no one will commit to anything, although I have read that there will be an official answer coming out possibly next year.
Mike
www.EV-propulsion.com
Mike
