These motors would likely normally be used for a vehicle which steers by varying the speeds of the two driven wheels, so it would have two separate controllers, set up to run in a coordinated way. Separate motors like this in a 24 V system that doesn't use them for steering are certainly possible but would be rare, so controllers set up to be used that way will be uncommon.... But I can't seem to find a speed controller that works with two motors. Would I just wire the motors to the same speed controller or is that a horrible idea and there's actually a controller with two motor connectors that I just can't find?
There's electric bikes and scooters that use two motors but I don't know how they work. Do they use two speed controllers? Or another type with a special adaptor or wiring for dual motors?These motors would likely normally be used for a vehicle which steers by varying the speeds of the two driven wheels, so it would have two separate controllers, set up to run in a coordinated way. Separate motors like this in a 24 V system that doesn't use them for steering are certainly possible but would be rare, so controllers set up to be used that way will be uncommon.
Two motors on a bike are rare, and a mobility device (sometimes called a "scooter") which uses two motors is usually a power chair that steers with them... but yes, there are some devices that use two motors the way you want to. They're just uncommon. If you can find one and can get close enough look to see the controllers (there are likely two), that would be a good start on finding possibilities.There's electric bikes and scooters that use two motors but I don't know how they work. Do they use two speed controllers? Or another type with a special adaptor or wiring for dual motors?
Does that mean there's another "controller" that connects the two speed controllers? If so what would it be called?If you can find one and can get close enough look to see the controllers (there are likely two), that would be a good start on finding possibilities.
So if I needed a 400 watt controller for one motor would I need an 800 watt to run both of them or??These are high school kids with ambition, not bags o money adults, Mr Theory 🤦♂️
Just connect the wires of the motors together, Black to red of the other motor and red to black of the other motor (because they need to turn in opposite directions). That way you can use one controller to run both motors. Same voltage, double the current of one if you want full power.
Later floydTBH, I didn't read the nameplate right and saw it as 34A. Darned eye infection
In production EVs, one of the several controllers coordinates the motor controllers - the name will vary depending on the vehicle manufacturer. Some controllers for small equipment (such as those from Curtis Instruments) are set up in a master-slave arrangement, where the accelerator input goes to one of them, and it tells the other controller what to do. In both designs, communication between controllers is over a network communications link.Does that mean there's another "controller" that connects the two speed controllers? If so what would it be called?
Edit: Or could I wire two speed controllers to one throttle control and one battery
Now you're engaging in something called "creeping elegance", the pitfall of everyone new to defining systems, where your initial application is lost sight of for something more elegant or for greater capability:Yes the most important thing is to get them running, my school has all the machines though to CNC our own gears so once we get them running we were gonna do that. We found out the top speed was only like 8mph and that is too slow for my liking
