What's your budget for the EV conversion parts?
What's your electrical/mechanical skill level?
What's the minimum performance and range that you require?
What's your budget for the EV conversion parts?Please help.
Electric part will be done by company that produce low budget EV. For mechanical, I will use local famous company that tune and modifies cars for race.What's your budget for the EV conversion parts?
I suspect that will not be enough for parts and labour given your performance requirements...Budget: 25 do 30K USD
We know the Tesla large rear drive units have problems with overheating on the track (see here and here). You could consider a dual motor approach using the Tesla small drive units or follow Chris Hazells attempts to split the inverter and stator cooling on the large drive unit.Performance : 0 to 100km/h in 3.5 sec - range in dynamic track day mode plus 20km
I think the challenge is deciding whether you need one or two motors to meet your performance goals... from what we know today I think it's more likely you'll have success with two small Tesla drive units because of the known cooling issues with the Tesla large drive units.My idea was Porsche Cayman, or 2000-2002 Porsche 911, or Subaru BRZ/Toyota GT86, or ... I need your help![]()
I will post a detailed list of my build costs when I get a moment...So can you Kevin make me approximately cost estimation for the parts in total without battery - for my request setup?
I don't know why it would be likely to be easier to stuff Telsa drive unit into the back of a BRZ/FR-S/86 than into a 370Z. Neither one is designed to fit an electric motor in the area of the rear axle, or to have any mechanical part extending rearward from the rear axle line. The BRZ/FR-S/86 might be relatively cheap, but it is small; that's what you want, but it also means that fit problems could be greater than with larger "sports" cars. There have been Tesla installations (well, at least one) in the Factory Five 818 kit car, which uses a Subaru Impreza rear suspension like the BRZ/FR-S/86, but the 818 uses none of the stock suspension arms and nothing like the stock subframe.So what to do about donor car? I [thought] Nissan 370Z was perfect for this conversion, but it is to heavy and rear part of the car is to expensive to customize so Tesla unit can fit.
So what to do? Which two door sports car to consider?
Please help.
A complete drive unit with the motor in front of the axle changes the packaging issues in a typical front-engine and rear-drive car, but still isn't easy - I can't think of anyone who has done it. The most popular candidate discussed for this would be a Nissan Leaf unit.Ok, lets forgot Tesla for the moment. Which car to use than? Which motors and controllers, any suggestion?
