Hi
I am have some space constraints in designing racking for replacing my lead w/ Li and need to make a decision in one area how much to worry about adding stiff end plates, or just thinner and less supportive strapping.
I was thinking about this, It seems to me that I need enough support structure to retain my batteries against 10G in all directions - this support structure should be able to squeeze and constrain my cells from swelling
If my battery support structure can't resist the swelling then it is too weak for road use
If it is the pre-compression that is the problem I am sure something can be done with low angle wedges tapped into place and then retained
