Drawings are great, but just a precaution for any newbies on the site, maybe put a title on the drawing itself that states something like "proposed wiring diagram, not complete, do not use" or something like that just to make sure someone doesn't copy an in progress diagram that could be unsafe or harmful.
If taken litteraly it looks like full pack voltage/current goes through your ignition switch, and an amp meter will have a shunt or hall effect sensor and not connect directly to pack voltage as shown, I also wonder why you have a breaker and a fuse in the + line. I can't imagine you being able to find a 500-1000A DC breaker rated for 150+ volts, I would stick with the fuse and an emergency disconnect.
Also I don't know if it was that charger but I've read that some don't like to be turned on without load, the way you have it that could happen. I would ask the manufacturer for recommended wiring.
And the motor is a Warp (not Wrap) 9, but keep working on it, I think drawings are great and a lot of people are visual learners and they would learn more from one drawing than reading this whole forum. Once you have a final version post it up with details of your goals/car/performance expectations for others to reference and use.
