1 - 1 of 1 Posts
Hi all,
Following with the Mini Conversion, you can see below some pics. That goes fast.
I need your help, I have some electric programs to calculate the section of these wires. But, not sure if I'm doing properly. The battery pack is around 96s or 100s for 28kwh, so probably maximum current no more than 100Ah. And the motor I'm using is the Leaf EM57 with the inverter.
Any one could help in these calculation ? which program or tables to use.
Thanks in advance lads.
1 - 1 of 1 Posts
