Hello,
I am looking to wire two Agni 95R (72VDC, 230A continous, 400A Peak) in parallel. The batteries are 6 lead acid wired in series and will be able to produce 800A for 10 seconds.
What size wiring would be required between the batteries for connecting them in series, as well as the wiring for connected each motor controller to the motor?
Is there a general rule for the gauge of wire that is needed for the maximum current that will be seen through that wire?
Thanks for any replies.
