1. Is your controller going to work with 45v? (There are multiple versions of the Curtis 1238)
2. Are you using a BMS? (I think you should) Each Tesla module is a string of six cells. When you connect two modules in parallel, you have two parallel strings. When you then repeat that at the other end of the car, you have two parallel strings in series with two more parallel strings. That will present a challenge for selecting a BMS.
If you are trying to reduce costs/weight/space by omitting one tesla module, and if your controller can operate at ~91v, then you should consider wiring the four tesla modules in series. If you plan to drive on the highway, then I think you should consider designing for five modules (or more) and a nominal battery voltage of 112v (or higher).
