Hi. Help me put together a list of parameters for a practical EV motor. Notice I didn't say "ideal" or "dream" motor but something that could be used for a typical EV conversion and it doesn't cost an arm and a leg. I have a list of motor rewinders I plan to contact with these params to see if they can make 'em.
- ACIM 3 phase, 4 pole
- 100VDC nominal voltage, up to about 250V
- 40kW sustained, >80kW peak
- Class H insulation
- Vector/Inverter class
- Insulated bearings
- Shielded stator
- 6000 RPM max speed
- Peak torque at ~3000 RPM
- About 9" diameter x <17" length
- Dual shaft
- C-Face/base mount
- Inexpensive, rebuilt/rewound
I'm almost describing an HPEV AC50 motor, aren't I? hmm...
Keep me honest with these and add/remove as you see fit.
JR
- Shielded stator
- Dual shaft
- C-Face/base mount
JR
