Jeep:
Fun begins where roads end
I woke up with an idea
A mechanical, nut & bolt actuated, Grille Press
Like, maybe cut the perimeter of the grille (using the CAD template) out of a piece of ~1" MDF (Medium Density Fiberboard)
...& use both pieces
The top would be the negative (-) side) or mold
...& the bottom positive (+) side) would be the die
Then, insert a piece of the 18g steel in between
...& use a bunch of nuts & bolts to clamp the (2) pieces of the "mold" together
...mostly around the perimeter
...but also, strategically placed in the light (sockets) & grille slots
I'm thinking it should "press" the die into the piece of steel
...& then, continue to form "it" around the die, inside of the mold
Here is a quickly drawn side view (hopefully it makes sense)
Probably divide the "pressing" in a few "steps
...like do the perimeter first
...then, "press" the grille slots
...& finally, the head & marker light indentations
