While the paint is a drying, I looked into the wiring/connections for the (2) SC's
...& worked on installing the fuse box
Mounting it right about there, leaves plenty of room for connections
These speed controllers from Alfa Wheels ALFA WHEELS have all of the wires/connections labeled
...& they even come with all of the mating Molex connectors, that are necessary to connect the wires with/to all of the signals & accessories
They are really easy to install, you just have to bare ~1/8" of the wire
...& insert it into the terminal (as such)
Then, crimp the "upper" section of the terminal, to the wire
...& the "lower" section, to the insulation on the wire (for additional support)
Then, simply insert the "wired" terminal into the Molex connector
...& connect it to the appropriate connector ,on the appropriate SC
