Did anyone notice that the front upper shock mount only has (2) bolt holes?
...& not (4) like the rear
It's because, the (4) level selectable "lift" concept could not be used (on the angle) in the front (like in the rear) due to the shocks hitting/clashing with the axle tube
...& having the (4) holes horizontally, didn't effect the height very much
A solution (many Jeeps use) would be to make a couple of "modified" lift pieces (upper shock mounts & shackles)
...but, they would probably be height specific (meaning a different set of brackets would be needed, for each height)
I'm not "messing" with this, (for now) I just wanted to mention it, before moving on
