We are beginning to see wrecked Model 3's at the breakers
Here is the first teardown video that I've seen;
Looks like you're right. This might have been partly a deliberate effort on Tesla's part to keep people from easily reusing(and abusing) Mod 3 modules. Are overall pack dimensions called out in the video? I wonder if the whole pack, possibly with the electronics hump, could be used under larger vehicles, like your van?Much like the Munro reports had suggested (here), it looks extremely unlikely that the large modules can be split into smaller pieces... that probably rules these batteries out for most conversions![]()
Perhaps, but I suspect they don't care about that. Fewer modules reduces assembly and interconnection complexity, so it seems like a natural evolution to me. They probably don't care about having to replace more cells in a single-module repair replacement, because they just replace the whole pack anyway.This might have been partly a deliberate effort on Tesla's part to keep people from easily reusing(and abusing) Mod 3 modules.
I've wondered the same thing about most EV packs (Leaf, Golf, Bolt...), since they are all basically flat plus lumps under seats, and often include at least some of these supporting components. Because there is only one lump on this one (at the back for support components), it might be a simpler and thus particularly good candidate.I wonder if the whole pack, possibly with the electronics hump, could be used under larger vehicles, like your van?
I only fast-forwarded through the video (I couldn't take and hour and a half of this sort of garage chat), but I didn't see a tape measure appear at any point.Are overall pack dimensions called out in the video?
It looks like the two longer central modules (25s) might fit in Kevin's under-floor box if they are not too long; the question is whether one both of the shorter side modules (23s) would fit across the van anywhere. Is a model 3 module more than twice as long as a Model S/X module? Fitting the whole pack, if possible, would be a more severe structural change, especially if it intruded into the rear suspension structure area.I wonder if the whole pack, possibly with the electronics hump, could be used under larger vehicles, like your van?
Crikey. An hour and a half. Have you seen it? Any good?We are beginning to see wrecked Model 3's at the breakers
It's the usual EVTV format... tons of repetition and opinion with the occasional gold nugget... I play them at 1.5x in the background while doing something else... then stop when I find something interestingCrikey. An hour and a half. Have you seen it? Any good?
No.Are overall pack dimensions called out in the video?
The 'hump' could be removed easily leaving a large, flat 'pizza' battery box... the box wouldn't fit under an early VW van without modifying the chassis extensively... it's possible the modules would fit between the chassis rails but I think they are longer than the space available. That said, the box would be a great fit for some of the larger RV conversionsI wonder if the whole pack, possibly with the electronics hump, could be used under larger vehicles, like your van?
Sent from my LEX720 using TapatalkLooks like you're right. This might have been partly a deliberate effort on Tesla's part to keep people from easily reusing(and abusing) Mod 3 modules. Are overall pack dimensions called out in the video? I wonder if the whole pack, possibly with the electronics hump, could be used under larger vehicles, like your van?
Sent from my LEX720 using TapatalkAnyone know the voltages of these new modules?
Sent from my iPhone using Tapatalk
Sent from my LEX720 using TapatalkAnyone thinking of reusing M3 modules will just have to design their project to suit these new sizes and voltages.
Shouldnt be a problem if its considered from the start of the project.
And its early days, but i would not be surprised if someone doesnt figure out how to electrically reconfigure the module voltage/Ah design for different applications......just as was done with the mod S modules eventually.
It's in the video...Anyone know the voltages of these new modules?
Excellent!Jehu has produced a shorter version of the EVTV video
