1 - 3 of 3 Posts
I've recently acquired an unfinished kit car project that i'm hoping to complete using EV components.
The car is RWD and i was hoping to either just use direct drive or get a gear reducer of some sort. I'm looking for a pretty decent power output.
I was thinking of using the following components but i want to check with some people that have more knowledge to see if this system would actually work.
Motor - Netgain Warp 11HV or Kostov K13 Direct Drive
Controller - Soliton 1
Batteries - 72x Sinopoly 200AH LiFePO4 3C in series - 230.4Vx200AH=46Kwh
Charger - Eltek 67.120.0 150-260V 10 Amp
BMS - Orion 72 Cell 1000A
Car should way about 1200kg and is somewhat aerodynamic, I'm hoping to get plus 100mph and a 0-60 time of less than 6 seconds with a range above 130 miles.
Would this work as i expect or have i over-calculated the performance such components would give.
Thanks for any help.
Edit - Am i correct in thinking that because the batteries are 3C and 200AH they will produce 600A which multiplies with the voltage to give power output? 600A*230.4V = 138.24KW
Hi
My car has a similar setup
800 kg
Hitachi 11 inch forklift motor - direct drive to a Subaru LSD
Paul and Sabrina controller - set to 1200 amps
12 Kwh of Chevy Volt cells
Range - 40km
Sub 6 seconds to 60 mph - not sure about top speed
At the end of the 1/8th I was doing 85 mph (8.6 seconds) - but I had a lot of wheel spin
With four times the batteries and almost certainly more aerodynamic then 130 miles is probable
1 - 3 of 3 Posts
