1 - 6 of 6 Posts
What is your project? I'm just wondering if a cheaper alternative might work, since that board is pretty beefy.\
EDIT: I just looked at your first video. that's the luckiest junkyard find I've seen. Holy smokes that's some money in parts. WOW.
Sent from my SM-N960U using Tapatalk
Hey jbman.
I guess if you saw the video, you saw what my project is. When I saw that motor in the junk yard I just about peed my pants. Unfortunately it was left outside and all the equipment is bad. The motor and adapter are the only parts that still work.
I plan on using a Prius IGBT. Video 3 shows the board i was making. I though that the P&S would be an easier option. What do you suggest?
Hey jbman.
Paul's board is very good. I'm using it in my MG Midget right now, and with some good IGBTs it's a monster. Duncan and several others use his stuff. I'm not sure what IGBT is in the Prius, but Paul's board requires three IGBT half bridges, iirc. Is that motor a Warp 9? I dont think getting three suitable IGBTs at that power level would be very pricey, and his board is pretty easy to use.
I assume that's your MG on their website? Nice!! My dad had an MG, I liked it but it would have been better without that pos engine.
Yes it's a Warp9. I couldn't find a data sheet on the prius igbt, I probably won't either. Now I need to figure out how to get $300. I though there'd be someone with a botched project or something wanting to get rid of theirs. I might have to wait til after graduation.
I believe Paul sells an unpopulated board. If you're comfortable assembling it and programming the chip yourself, that may save you enough. He has programming instructions and such. This page is a good example of building the controller: https://www.instructables.com/id/200kW-AC-Motor-Controller-for-Electric-Car/
That's the ac build, but the DC is almost exactly the same. The three phases are tied together into a single output for the DC board. There are lots of examples of builds using this stuff in all kinds of configurations.
1 - 6 of 6 Posts
