41 - 60 of 124 Posts
Discussion starter · #41 · (Edited)
Back from Paris for 15 days and I've been working on the spreadsheet.
Now I take into account :
- max motor voltage
- max motor amp
- max battery pack voltage
- max battery pack amp
- C rating setting
UI has been modified to have every thing in logical blocks
That's still a simulation, based upon what I've understand about EV. But i'm not a specialist. Just doing that for the fun.
Use at your own risk :eek:
Discussion starter · #43 ·
I'm using OOOCalc 3.2.0 at home and OOOCalc 3.2.1 at work.
I don't understand the problem, as you should'nt have any value in the cell "Power" for "v=0". I have deleted the formula in this cell, as you can see in the image in my post.
Try to download again, and check your Open Office version.
Regards.
Discussion starter · #44 ·
I've noticed I don't check validity of the "coeff of rolling resistance", and if you enter a text value for exemple, you have the problem, but it also mess up the corresponding calculated force "Fr".
I will post a newer version with all data entry checks verified.
Regards.
hmm - same thing in other computer and with all earlier versions of calc
ooo 3.2.1; build 9502; oo update says - up to date
can be bug in macros, file path name,etc? what is your build?
Discussion starter · #48 ·
I think the simulation is correct when pack_amp >= Motor_Max_Amp.
If you set the C rating two low or choose a battery with low amperage then motor_power can be more than pack_power.
Something is wrong.
Still working on it.
Discussion starter · #50 · (Edited)
As promised, new version taking care of battery pack max deliverable power.
I now see another problem :eek:. Uptime, Range and Mileage calculations, are based on minimal power demand. They don't match with the acceleration time which uses max power.
Looking for some graph to show that out.
Comments welcome.
Discussion starter · #51 · (Edited)
Some new works :
- Bug corrected : macros won't initialize when spreadsheet has been previously saved with activesheet <> "EV"
- Better handling of "low amp torque"
- added : sport mode : you floor the pedal to reach max speed and hope everything goes well (no ESP yet)
See new graphs in the first post.
Some new works :
- added : sport mode : you floor the pedal to reach max speed and hope everything goes well (no ABS yet)
Aloha, I tried to D/L the openoffice Program to make use of the this neat Calculator. (from ooodocs.org) and managed to get a virus. Any recommended sites to get the OO program? thanks
Francis
I got a good virus-free version of OO, but the spreadsheet contents have a lot of ### and values for motors
Cannot change from AC55 in the ev sheet.
chart in EV is also filled with #value! in the uptime to 3rd gear column
What am I doing wrong?
thanks
Francis
