1 - 7 of 7 Posts
Hi all, I have a Renault Kangoo electric with MES DEA parts and with ZEBRA battery pack. Does anyone have a diagnostic software for ZEBRA battery? I need to heat up the battery before charging, but to start this i need to clear the error codes. My understanding is that the BMS generating an error code once the battery is cooling down.
Any recommendation would be helpful.
Thank you.
Good afternoon,
After solving the software and hardwer issues, finally i can connect and access into Zebra BMI, but i am stuck again.
The diagnostic tool is asking a username and password if you want to erase the error codes, the documentation is mentioning for erasing there is no need to get a username.
For other level is important which is normally provided by the combany.
Best regards,
Levente
Hi anyone have a solution to software and hardware issues. I probably have the same problem it says no can hardware. As I have read elsewhere they may be due to the usb drive being too new and that I need version 2.x but the oldest I find is 3.x for the peak can interface. Running windows xp
1 - 7 of 7 Posts
