Nice lawn Major!
It is from this thread http://www.diyelectriccar.com/forum...ions-deck-motor-riding-lawn-moweri-45125.htmlWill you give us some specs? Series or shunt wound? Controller or hard-wired? If series, do you have to limit speed or do the blades provide enough limiting force?
That is a pretty nice set-up. Interesting idea to mount the deck in the front. Have any performance issues due to that? Also, is that the motor situated under the seat? I would then guess that the batteries are under the hood.Here's a deck I did a while back![]()
I helped Tony build the deck to replace the original Electrak deck which was also front mounted. Tony likes it out there. He has a flat yard. Don't know how it would handle on hills.That is a pretty nice set-up. Interesting idea to mount the deck in the front. Have any performance issues due to that? Also, is that the motor situated under the seat? I would then guess that the batteries are under the hood.
Hi TheRed,Any idea on the efficiency of a belt system or where I can look that up?
Median efficiency of the surveyed industrial and agricultural
belt types and constructions is 96 per cent. Within
rated and application power levels, efficiency ranges from 90 to 99 per cent depending on belt type
Oh my gosh, it's an old cone drive. What a blast from the past! I remember helping my boss put one of these on display 36 years ago when the technology was brand spanking new and I was working as a bicycle repairer at a lawnmower sales & fixit place....Hey Guys:
Here are some pics of the lawnmower. We have already removed the engine and if anyone is interested in a 16hp Vangard Briggs and Stratton (still runs) shoot me an email ([email protected]). (I don't know why you would be interested considering the forum we are on but....)
Anyway the transmission of the thing is all jacked up. The engine runs and the blades will turn on but the mower doesn't actually move. This inclines us to think we should just rip everything out and go with a motor for each wheel running off the chain final drive rather than try to fix up the transmission. I have also read a couple articles describing the issues these cone drives had so going with a technology proven to go bad doesn't give me a good feeling.
On the battery front, it looks like we will probably go with a thundersky or HiPower 100ah LiFeSO4 battery
Wow! Dinosaurs ran on cone drives? Who knew?Oh my gosh, it's an old cone drive. What a blast from the past! I remember helping my boss put one of these on display 36 years ago when the technology was brand spanking new and I was working as a bicycle repairer at a lawnmower sales & fixit place....
Either a circuit board to interpret the signals or maybe a simpler thing might be two pot boxes. One for the forward direction and one for the reverse direction. Hook the arms to a spring so that when going forward the spring connecting to the reverse potbox stretches and vice versa. Hook up the micro switch in the potboxes to enable forward/reverse as required.Our current issue is figuring out how to set up the control sticks. The controllers for the drive motors accept 0-5 volts. However, trying to get that sort of behavior mounted to the sticks is an issue because we still want to be able to have the reverse capability of the zero turn. The controllers have a switch that must be enabled in order to reverse the motor.
In other words we want some sort of functionality that looks like this:
+5v (full forward) ---- 0 Volts (stationary) ----- +5v (full reverse)
We were planning on using some sort of potentiometer set up but nothing we can think of would allow us to map this sort of behavior. If anyone has any ideas, that would be awesome because we are a bit stuck on this issue!
Hi TheRed,In other words we want some sort of functionality that looks like this:
That may be more practical idea than you think. Considering the price of gasoline and where that is headed, starting to convert some of those mowers (both zero turn and standard) to electric may not be that bad of an idea. Considering the amount of mowers you have to maintain, do you live in a more populated area? I ask because if there is a decent college nearby you might be able to get a class full of engineers interested in doing such conversions. Plus with college funding you might even be able to get the entire thing paid for.Greetings to all. this is my first post here on the site.
By a strange coincidence, I am a mower mechanic for the local school district. I keep up a fleet of 20 riding mowers of all sizes and types. But, 14 are the zero turn type. 10 are the Hustler 72" Super-Z and 4 are the 64" John Deere Z-Trak type.
Both types use individual fixed displacement hydraulic wheel motors, but one has a unified double pump and the other has two/single pumps.
Not to start any bad feelings, but either would be easy to do a single DC motor to drive the hydraulic pumps and mower deck, (which is direct-belt driven).
The hydrostatic pumps are of the positive displacement, variable volume type with a swash plate to adjust the output. There is no torque converters or slippage involved. they would be a great match for DC power.
The electric motor would need to be RPM controlled automatically by the controller. The deck is always an electric clutch. the variable displacement pumps would take care of for/rev and speed settings.
Turn on the key, and the DC motor starts at a set RPM. drive off trailer to mowing location. start the deck with a toggle switch. A sensor would be needed to throttle up and down with load to stop over speeding when suddenly unloaded.
Oh, well , just dreaming.
MIZ
