The shunt resistors had to be replaced due to a short.
I have now given the boards an extra clean but no luck.
Longest Sense wire is about 2 ft long, but there are the same issues even if they are changed.
So i have measured the voltage of each cell across the screw terminals, i have then compared it to what was displayed on the Monitor at the time. I then swapped each BMS12 so it was in the other location and repeated the readings. The results are above.
So there are faulty readings in the exact same location even if they are reading different cells.
