Zeva mc1000c controller will not work
1314 Views 1 Reply 2 Participants Last post by  riba2233
Connected to 0-5 volts throttle and will not spin the motor unless disconnect one of the variable voltage cable, move the throttle past the 1/2 point and then connect the variable voltage cable, the motor will spin and monitor will show 50 % or more throttle, if throttle is lowered below 1/2 point the motor stops spinning and set throttle error message
1 - 2 of 2 Posts
0-5 volts throttle requires NC safety switch, did you connect it? Also, are you sure you got all the wires wired correctly to the 4pin connector, in the manual pins are viewed from the controller side.
Do you have the programmer? If yes, you can debug the throttle with it, it shows the throttle level on it's display:
1 - 2 of 2 Posts
