I was driving today to the garage for an alignment (have to wait and drop it off Sunday - sigh) and the zilla flashed the check engine light slowly but did not register any trouble codes. I reviewed the manual, but it didn't give a list of what would make it do that.
To sum up,
This happened while driving.
There were no trouble codes. Yes, I checked for previous codes. There are none.
The battery voltage was fine. Well above warning level.
It continued driving just fine.
I was driving at low power levels (50-100 battery amps).
Nominal pack voltage is 228V.
What would cause this? It was around 100 degrees outside. Could it have been cutting back due to high temperature? I have the full liquid cooling unit (from evsource) and it seems to be working.
Thanks.
David Brandt
Choose the right car based on your needs. Check out Yahoo! Autos new Car Finder tool.
http://autos.yahoo.com/carfinder/
To sum up,
Thanks.
David Brandt
