Did you turn on the charger while connected to the battery pack? Just as a test, try to turn the charger on while disconnected from the battery. It should beep and flash red LED, indicating there is no battery connected. If it doesn't do that, then charger is defective and must be repaired.
Working NG3 will always start with red LED and fans will spin up, even when connected to a fully charged battery, then it would quickly sense the battery voltage and go to the next phase ( blinking red LED ) and then to yellow and then to green. If yours doesn't do this, its probably broken.
