21 - 40 of 118 Posts
Discussion starter · #30 ·
You absolutely need AC. I can't imagine wheeling without engine braking. It gives you the same control as going up hill. I am using a 4 to 1 t case and stock 3.73 ring and pinions which gives me a 70:1 overal crawl ratio. I run about 115 to 1 on my ICE samurai. I also notice that I use less amps at a higher rpm so a little lower gears are good, but I don't need as much as the gas rig.
Discussion starter · #32 ·
What I have found is that most of the time while wheeling, I drive with my left foot on the brake since I rarely need the clutch. Almost like an automatic. Plus it saves energy. I have no need for an idle. Some use it for air conditioning or power steering.
You will love it. In my 2000 Ford Escort, I switched from 15 8 volt lead acid batteries to 44 100 AH Lithium Iron Phosphate cells.
The car is 700 lbs lighter!
Acceleration, range and top speed are all tremendously improved. It turned my Science Project into a nice daily driver.
Discussion starter · #40 ·
Funny, I just got back from my first ride with the Volt pack. I did 15 miles a lot at highway speeds. I cannot believe the improvement. Almost no voltage sag, feels like twice the power and acceleration. I got the ev grin today. I am so stoked. I would drive more but I dropped my charger at Elcon this morning...
