I wanted to confirm my suspicions so my dad and I went on to remove the two battery boxes which were mounted on the bottom of the car with just 8 bolts each.
We don't have a lift so we had to do it with some elbow grease.
First we had to disconnect the main battery leads and the communication cables before removing the 8 bolts per box (16 total).
With the "ignition" turned off I disconnected the communication cables. You remove them by just turning them loose and then pulling them out. A push and lock by twisting system. You take them off at the side of the battery boxes.
Then the main battery leads, they work just like pneumatic connectors. You pull the knurled ring towards one side and then the two ends seperare easily. I put duct tape on them to insulate them. There are 3 places to disconnect, two between the motor and the front battery box and one on the side of the front battery box.
I used thick 1000V insulated gloves and a face shield just to be safe.
After that we were able to remove the battery boxes.
For the first box we decided to fill up the gap between the floor and the bottom of the battery box, to gradually lower it per side, one pallet at a time. Then we lifted the box up with my dad's trusty International 633 to put it up on some stands for later. It's not the most graceful way, but we had to make do with the tools we had.
You need a 13 and 17 millimeter socket for these bolts.
We got the job done but thought we should try it in another way for the next box. So we decided to support the box on the lowest point the car could go and then lift the car up to pull the box out from underneath.
It worked well but had to lift the car up higher than we thought because the rear box has a different shape.
We succeeded and put the box on a pallet with some wheels underneath to move it around more easily.
The next post will be about opening up the first battery box to take a look inside.
