Some good information is in this thread
http://tech.groups.yahoo.com/group/b...ns/message/179
And here
http://www.chemie.uni-regensburg.de/...x_edison-e.htm
The below info was posted on another group as "historical information" and I have never tested it, so no idea if it works well enough to be a real battery.
Anyway this is the cheap method of making a suido Edison Battery
Iron (anode) Plate
To make the iron anode, first mix 6 1/4 grams of iron oxide with 1 1/4 gram of ammonium chloride, then add distilled water a drop at a time until a stiff
paste results. The mixture will give off ammonia gas and will turn to a
white color. Working quickly, smear the paste well into a 1½ x 6-inch piece
of No. 20 or 30 close mesh iron or copper wire screening.
It will take about a day for the paste to thoroughly set and harden on the
screen, or you can hasten it by placing it in an oven set at no more than
130°F. When dry, lay screen in a solution of ammonium chloride (12½ grams to
6 oz. of water), for about 1½ hours to harden it further. This completes the
anode plate.
Nickel (cathode) Plate
To make the nickel cathode, first mix 6 1/4 grams of nickel oxide with 1 1/4 gram of ammonium chloride, then add distilled water a drop at a time until a
stiff paste results. The mixture will give off ammonia gas. Form this plate
directly on the surface of a 1½ x 6-inch. piece of .015 inch or thicker
nickel screen, which has been cleaned thoroughly with emery cloth. Working
quickly, smear this paste well into a 1½ x 6-inch piece of No. 20 or 30
close-mesh nickel wire screening.
It will take about a day for this paste to thoroughly set and harden on the
130°F. When dry, lay screen in a solution of ammonium chloride (12½ grams to 6 oz. of water), for about 1½ hours to harden it further.
Fill a wide mouthed jar or a 1000 ml. Beaker with 32 oz. of distilled water.
Dissolve 9¼ grams of sodium hydroxide (lye) in this water and add 1 gram of
common table salt. Sodium hydroxide is hard on the hands and clothes in its concentrated form, so don't handle the crystals with your fingers and always add the crystals to the water slowly.
Mark the iron oxide plate negative and nickel oxide positive now to avoid
mistakes. Connect a battery charger or car storage battery to the plates,
negative to iron oxide plate and positive to the nickel oxide plate, also a
direct current ammeter or digital multi-meter and a l0-ohm 25-watt resister
is added in series with the forming current. Turn on the forming current and
adjust the variable resister so that only 1 ampere of forming current flows.
It is important that you observe polarity right at the first charge.
Connecting the negative lead to the iron oxide plate and the positive lead
to the nickel oxide plate. This charge must be (2 or 3 hours), because the
iron oxide plate must be converted to metallic iron. It doesn't matter if
the plates gas in this forming charge.
Attach the cathode and anode plates to a strip of wood to test them. Fill
another 13-oz. glass tumbler with about 9 oz. of distilled water and slowly
dissolve 3 oz. of sodium hydroxide in this to form the electrolyte of the
iron-nickel cell. Suspend the plates in this liquid. Now your cell is
complete. Cell voltage on open circuit will be right around 0.75 volts for
this iron-nickel Edison cell.
