Article Tools Display Modes
Default Donor Car Selection
What cars make the best candidates for EV conversions?
Generally, the smaller and lighter the car is, the better. You'll get better performance, more range, and the conversion will cost less. It's a similar story to petrol vehicles, except there is a far greater economic advantage to keeping it small. It is not impossible to do heavier vehicle conversions but you will spend a lot more money to match the same performance as a lighter car. Generally look for the smallest car that will fit your needs. Aerodynamics will also play a significant role in the energy use of your EV, especially at higher speeds, so choosing a slippery car means it needs less power at a given speed and a smaller battery pack. It also makes sense to convert cars with relatively high mileage or even blown engines, since you can purchase them more cheaply, and greatly extend the useful life of the vehicle.
Here is a short list of possible donor vehicles for EV conversions ranked by weight
[/td][/tr]
Make/ModelWeight (lbs)GVWR (lbs)Weight (kgs)GVWR (kgs)CdA (square ft)Economy (mpg)Economy (L/100km)Links to previous conversions
Honda CRX (HF)1713224077810165.7455.2http://www.metricmind.com/ac_honda/main2.htm
Geo Metro (1st Gen)1850259084111756.841.55.7http://www.austinev.org/evalbum/type/GEO
VW Rabbit/Golf (Mk1)190021738639866.5307.8http://www.electroauto.com/gallery/vrabbit.shtml
Porsche 9142085280094612806.5259.4http://www.electroauto.com/gallery/vp914.shtml
Honda Civic (3rd Gen)2088302094913707.4337.1http://www.austinev.org/evalbum/106
Hyundai Accent (1st Gen)2100315795514356.629.58.0?
Mitsubishi Tredia21193100 (lbs)9601500 (kgs)6.4278.6http://www.austinev.org/evalbum/1114
Mitsubishi Mirage (4th Gen)2156358698016305.931.57.5?
Toyota mr2 Mk123002701104312255.8269.0http://www.austinev.org/evalbum/102
Toyota Corolla (7th Gen)23103498105215906.827.58.5http://www.austinev.org/evalbum/1078
Mazda RX-7 (1st Gen)2335? (lbs)1060? (kgs)6.31813.0http://www.austinev.org/evalbum/047.html
Mazda Miata (1st Gen, 90-93)24473784 (lbs)11091716 (kgs)7.02310.21http://evmiata.com
Datsun 280z 2630~33101196~1502~6.722.810.3http://www.evconvert.com/article/joes-280z-ev
Transam GTA 89 3230? (lbs)1465? (kgs)6.4239.7http://www.veperformance.ca
Pontiac Fiero26963650122516596.75307.8http://www.evalbum.com/894
Notes for adding vehicles:
The weights of some of the above cars vary slightly depending on the year and options, please record the smallest weight for simplicity. The statistics have been sourced from a variety of unconfirmed internet sources and should therefore be used as a rough guide only.
For the mpg of post 1985 vehicles use http://www.fueleconomy.gov/feg/findacar.htm
For the CdA of many vehicles try http://www.mayfco.com/tbls.htm, if the exact CdA could not be found record the Cda of very similar vehicles or previous generations and included a "~" to denote approximatly.
Also for weight conversions try: http://www.healthyweightforum.org/eng/converter.asp
And mpg to L/100kms: http://www.fadainc.com/mpg_100l.html
Created by mattW, 09-14-2007 at 08:36 PM
12 Comments , 21970 Views
Article Tools
