Hi all,
I've just bought an unfinished project started by someone else. This will be my first EV. I do my own mechanic (including engine swaps) and I'm a computer tech so I know many things about programming. So here how it goes...
Car:
2002 Hyundai Accent LC (3 doors, 5 speeds manual tranny)
Weight: 2190lbs (without batteries)
Controller (AC):
Curtis AC 1238-5601
36-48V, 650A max (210A 1hr)
with 1311 LP Handheld Programmer
Motor (AC):
Prestolite Asia ASDA 4004
15.5Kw, 30.3V, 405A, 1735RPM
Drivetrain:
custom adapter/mounting plate
custom flywheel (bearing supported) adapter shaft with a gear
pinion gear on the motor output shaft
chain driven (motor-flywheel) with 1:2 ratio to compensate for low motor RPM and theorically providing 3470 rpm at the flywheel.
Batteries:
None chosen yet (well, currently using four old 12V lead acid for test purpose)
Project Status:
The mechanical part is already installed and running. The motor mount will need some modification but that is no big deal for now. I will also need to do the power-brake part (vacuum pump). Most of the 4/0 gauge wiring is also done including a contactor but I will need some fuses for safety. I will also need a DC-DC converter to feed the car 12V system.
I'm now doing some tests with controller programming because the previous owner did not have all required information and I want to make sure the motor and controller operate adequately. I also know that this setup will NOT give me similar to ICE performance. It's a new project basically for learning purpose with EV. I would be glad if it could reach 35-40mph and be able to do 12-15 miles with a charge.
ok, now some questions
Am I ok to assume that 48V x 210A = 10,080W (13.5Hp) will be the available power for my car ?
I am not familiar yet with Lead Acid battery, can they provide 150-200A for 15 to 30 minutes without overheating ?
I will look at the wiki and all the guides, but anyone wants to evaluate my theorical top speed and also maximum distance if I use good AGM or deep discharge batteries ? What type/capacity should I use for my 12-15 miles target ?
Thank you all, I will post pics tonight!
Car:
Controller (AC):
Curtis AC 1238-5601
Motor (AC):
Drivetrain:
Batteries:
Project Status:
