My first attempt is a 2003 corolla which I bought from a neighbor for $300.
His son ran it for a week with no oil! I changed the trans to a manual and had an adapter made for a Warp9 motor. I plan on using 144 volts in the form of 12-12 v AGM batts. I know the range will be low but can't see where I could put 24-6 v. Since it is a front wheel drive I have to put batts under the rear seat, in front of the rear axcel otherwise I might loose traction. For charging I was going to but onboard 3 banks of 4 ea individuals to each batt so I won't have to worry about balancing and the AGM batts have to be charged at 14.5 volts or they will be damaged! Hows this sound so far??
