Hello !
I'm new on this forum and I will introduce the project that my team and I have planed for this year. We are building an electric single seat racing car to compet in Formula Student (FS) Challenge : http://www.formulastudent.com/default
We decided to use a AC Permanent Magnet Synchronous Motor for our vehicle, but i encounter some difficulties to find the appropriate one.
The specifications of the motor that we would like is :
- Peak power : 60kW maximum (FS rules)
- Maximum voltage : 400V (FS rules)
- Maximum weight : 25kg
- Peak torque (used during 5 to 10 seconds max) : approximatly 140 to 200 Nm
- Peak motor speed : minimum of 5000rpm
Car characteristics:
- Max car weight : 310kg ( 683lbs)
- Peak longitudinal acceleration : 0.85g – 1g (g=9.81m/s²)
-Wheel diameter : 2*0.254 meters
- Max speed : minimum 110 km/h
- Max torque on rear tires : 750 to 850Nm
To obtain this torque on the wheels, we will use a reducer.
We are limited for the battery capacity to a maximum of 7250 Wh and a voltage of 400V.
My main problem is that i can't find a such motor, except only one, the Mavilor MA-55 :
http://www.mavilor.es/pdf_products/ma_series.pdf
This motor has great performances :
- 16.8kg
- max speed : 6000 rpm
- peak torque : 190Nm
If we plan a car top speed of 130km/h (142rad/s with a 0.254m half wheel diameter), we obtain with a reducer of 4.42, a peak torque on rear wheels of 842Nm that matches perfectly !
However, we can't get in contact with this company, so we have to find another electric motor, but we don't find any one that correspond completly to all of our characteristics (especially the weight !)
Here is a list of all other motor that we found, but are twice the weight we limited for the motor :
Baumueller DSD100
Boschrexroth MSK101D-0450
Boschrexroth MSK101E-0200
Boschrexroth MSK101E-0300
Boschrexroth MSK101E-0450
SEM HR190J8-180S
SEM HJ190K8-180S
EVE M2-AC15/4-AS/L
Evo electric AFM-140
Brusa ASM6.17.12
Thus, I would like to know if you know any company which produce such kind of motors ?
I already have a look in the forum, but i didn't find what me and my team need for our project...
Thank you,
Fabien
ESTACA Eco Racing Team
- 16.8kg
Baumueller DSD100
SEM HR190J8-180S
SEM HJ190K8-180S
EVE M2-AC15/4-AS/L
Brusa ASM6.17.12
Thank you,
Fabien
