Hi all,
I may be overthinking all of this, so I thought I should solicit some input to see what other people think/are doing for their systems. I've also been away for a while taking care of my newborn son, so natrually this project was put on temporary hold. Glad to say I am getting back to it now and still hoping to be done the conversion by spring!
Anyway, I'm using a Leaf motor/inverter in the back of the car and most of a gen 2 Volt pack up front. The leaf inverter housing calls for 13.5 LPM of flow, and I'm not sure about the batteries. I'm also planning on dialing up the power beyond the stock 80kW so more cooling is probably a good thing.
What I'm trying to decide now is how to plumb everything and how much flow to try and ram through the system. I could put the batteries in series with the motor/inverter (batteries first!) or I could use two pumps that tee(or Y) off right after the radiator and go back together at the rad inlet. Or, I suppose I could use a single, larger pump and then tee off to motor/batteries in parallel, but then I need to figure out a reliable way to balance the flow.
The leading contender for a single pump in a series setup is this: ELECTRIC BOOSTER PUMP (EBP23) (12V) SHORT - PART No: 9051 It advertises a flow rate of about 17 LPM with a 1.5 psi pressure drop. Not sure how much of a pressure drop I would see in my system, but between the batteries, motor, inverter and piping from front to back, 1.5 psi sounds reasonable?
What do you all think?
