Kei Truck Leaf Swap
1 reading
7.2K views 40 replies 8 participants last post by  98nchen
#1 ·
This is the Beginning of my First EV swap.
nothing is set in stone yet but Heres the going plan,
EM57 motor inverter charger stack,
Hyundai Kona battery Cells 96s1p, Or maybe 100s cause sounds cooler and squeeze a bit more wh,
Thunderstuck motors BMS, (was one for sale here but the guy backed out so ill buy new, (good to support those guys direct I've heard they do good work)
Suzuki Carry minitruck, Plan is to make an adapter from the EM57 to the truck tranny to learn the gear ratios, and maybe later go with a single reducer
Picking up the EM57 motor setup Today!
should also be getting the Kona power steering guts and power brake booster stuff, (getting the entire front subframe, so ill have the shaft to make a coupler for the truck as well.
Current Budget for this project is 10k and I should be able to hit that pretty close.
Will continue to update as I buy parts, And make another post to this thread later today with picks of the leaf parts haul if all goes too plan!
#2 ·
I forgot to mention I've pulled enough scrap wire from the local industry recycle bins to wire this entire truck, including,
some 50mm^2
some 25mm^2
bunch of 6awg for the LV
J1772 male and female flying lead connectors including pilot dummy to talk with EVSE (I don't have an EVSE at home yet so time too make one :)
I've also collected an assortment of 14 12 and 10awg tew marine wire for more LV wiring and fuse/relay boxes to boot
#3 ·
Few more things to note,
I plan to daily this and as such a few more things,
Will be doing a proper HVAC of sorts for the cabin and battery heating and cooling. (I'd say the big thing here is battery heating for the coldish Vancouver winters.)
and later gonna do a pallet style forklift drop in DC genset to make a long range extender system, (I'm aware the internet is very divided on this but I'm gonna do it anyways, after all I would be doing this if it wasn't just for the "because I can".
Genset gonna happen only after the main build is done and driving. but that's the plan at least.
#4 ·
Parts Haul was a resounding success,
got the majority of the lv and lv components of a 2015 leaf, including all HV components and connectors, as well most all the LV harness parts,
Also got the stock leaf 96s BMS which will save me a fair bit off of buying the thunderstruck BMS
ive been told the schematics are available for the leaf which should help with the cell tap wiring, (only really one shot to get it right, I do have decent Smd rework equipment and skills if required)
Excited to have the
Power Steering
Power brake booster
ABS pump
AC compressor,
cabin heating/cooling element,
Should make this swap feel like a pretty modern creature comforts vehicle.
Since I've got essentially all the electric bits from a leaf (and saved a bunch of cash in the process) ill grab a resolve EV controller to and wiring harness to really ease of the work load in the wiring department
Also got
Motor mounts,
front subframe assembly with the bushings,
and dash subframe,
which will be awesome to save time fabricating new mounts for all these parts
Bunch of other goodies hiding here too, contactor box with pre-charge
battery heating pads,
relay boxes,
steering wheel
wheel speed sensors, and seems a lot more.
So as it seems today I got all the new brains, and shortly ill be getting the new Braun for this build.
Excited to get this Project kicked off.
#9 ·
Update, I wasn't able too get the motor out of the car in one peice so I split it up into its 4 components (I also have the front diff, so ill be able to make a coupler with that.
Ordered up a Zombieverter, might as well have some fun here, as i plan to add some other stuff later maybe CCS and such.
also I had salvaged a j1772 cable and so I've ordered up a openevse 50 Evse unit without the cable too save some money there, this way I can actually charge at a reasonable rate once I'm at that point.
Also was able to salvage a fairly long chunk and red and black 42mm2 cable seems it'll be usful here for somthing.
Still need to puck up that batteries, and continue on the hunt for a suitable minitruck.
#10 ·
Okay, Now reading into ZombieVerter, seeming to be missing some info, the Current shunt.
This IVT-S Shunt is pricey,
1. is this what im looking for, i understand the 1 and 2 can networks and 0,3 voltage readings, and im thinking +-1000a?
2. are the ebay listings for these in the 200$ range legit?
3. EVTV has them but not too far off of the digikey pricing.
Excited to continue things are happening :)
#13 ·
Thanks for the heads up,
I plan to upgrade the inverter and pack later on and thatll get me really close too the 300a, so i grabbed the 500A one, waiting on the connector set for the sensor yet
Also started tearing into the harnesses and labelling battery IGN and CAN signals in preparation of the ZombieVerter.
I split apart the PDM and Inverter harnesses here because I'm fairly sure i wont be able to fit the stack all together.
Been watching a lot of Cat videos it seems about Car parts and Inverter setup, trying to get up too speed and have as much of this prepared as possible.
Many more too go :)
#14 ·
Continuing on,
found relevant specs for the stock Leaf cooling pump and its in 2hz pwm to make it not spin at full speed.
Next up Contactor Block from the leaf.
seems the contractors are mounted in opposing directions and therefore polarity doesn't matter here as one or the other would have the correct magnet direction to blow it out,
on the other hand, the always hot side does matter as the precharge circuit wouldn't work otherwise, did some more digging and have labelled them as I've found.
dug a connector that matches the blocks LV connector, found the pin descriptions from the factory services manuals (once I found what I was actually looking for the naming is not clear lol)
bused the positives together as is described on the Zombieverter page and labelled the 3 negative coil pins.
Also Opened the Front gearbox/diff thing too harvest the coupling for the motor.
Next up find the BMS info in the Service manuals, if its there:)
EDIT, the BMS info is literally on the same page as the contactor info i found. Wiring continues
#15 ·
Note:)
no idea how long the Zombie takes to come, but the wait will be worth it, im super excited to get digging into the weeds of it
I'm sure this goes the same way for most, it just cant show up fast enough,
I've ordered the 3m harness and Enclosures from 2ali vendors as that's 2x the chance of it actually showing up, although as of late Aliexpress has been super solid for me
#16 ·
#17 ·
Okay so BMS pinning all figured out as of now, I have a "white bms" which requires the 4temp sensors and a temp sensor harness with only 3, so ill do the resistor change thing to make it work as is.
Next thing I want is the Leaf power steering,
I've seen 2 leads with info on it but nothing too actually using it,
just asking, no real info?
i thought ill just plug it in and see what happens
So I set it up on a stand, wired up the main power and the ignition to a 12v 35a meanwell supply (adjusted too 13.7v), powered it up, and it works!?!?!?
seems like many can devices this power steering unit falls back to some form of functional even with no CAN at all.
the pin descriptions for the Ignition and CAN came from the Service Manuals "stc" steering_control_system document.
#22 ·
I'd love to see more pictures. I went with the Resolve EV but I always wanted to build an EV kei truck.
There will be lots of pictures too come, for the time being I'm getting all the electrics pinning figured out and tested, I do not have a truck yet lol, all I know is I'll be getting one soon for this project, looking for a nicer example as my skills are in electrical and not body work.
I guess my project is a little backwards as most start with a vehicle that they plan to swap :)
#23 ·
Welcome! Excited to find another Kei fan!
I've been doing extensive research on converting a truck for a little over a year and just started the import process from Japan. I'm using a company called BeForward which has a large inventory but, as others have also experienced, they're a bit slow and lacking in communication. I'll be posting updates soon about the import process (on an ActyEV notes site I'm putting together) and I'm compiling resources to share!
Time for me to actually read your thread but let me know if you have any questions - I think we're both on a similar journey but I'm going AC50 for the motor instead of Leaf.
#24 ·
More updates,
I've got Batteries!
got 4x 10s3p modules of LG cells from a crashed Hyundia Kona EV and am currently having a blast designing a box and fastening system for them.
they will be rearranged into 4 modules of 24s1p to make the 96 for the leaf BMS
since I've got no truck yet its all just plans(with a lot of video and photo reference to guide me)
then again I love to mess around in cad and trying to make things parametric is a neat challenge for me.
here's my current design
I didn't get any others parts from either leaf of kona pack aside from the leaf BMS and the kona cells, so I've been looking for all the other required parts,
I found this amphenol service disconnect and fuse so far.
Not sure yet if I want a main battery connector or to use cable glands for the pack, not important yet though either
Zombieverters from JLC will be shipped soon, and enclosures are in aliexpress shipping land of who knows where.
Few next steps here, going to start tinking with the electric brake booster, i don't know enough about it yet to know if i can or cant use it, seems nobody has tried, but from ready the service manuals it looks as though the ABS pump is the more complex unit, and the booster is the more simple, I guess we will know soon (I do see 3 sets of CAN 😐)
#37 · (Edited)
Long time no chat,
I have not stopped work though,
Leaf motor is installed and truck runs on Electric power!
I made a driveline coupler using the inner spline of the Kei clutch and the existing leaf gearbox input shaft, rubber BMW driveshaft coupler was reccomended to me to take up any possible deviation on the shaft alignment, I 3dscanned the bellhousing and got the shaft alignment within 3thou.
Truck is being powered by magic in the photos.
