Newbie Battery Question
2.9K views 4 replies 4 participants last post by  TexomaEV
#1 ·
Hello,
I'm doing my homework for an EV conversion of a VW Ghia. One of my dilemas is a common one--the batteries. I can go with more affordable lead-acid batteries like from Interstate for around $1500+/- for their best heavy-duty deep cycle models for a 120V system. I commute about 10 miles round trip/day plus misc. short trips so maybe I'll recharge 2x/wk. Maybe I'll get 3 yrs out of that setup? Not sure how much range/acceleration I'd get from those batteries though.
I can also make a more substantial investment into some flavor of li-ion for north of $20K. That might last me maybe 8-10 years? (I'm worried about that actually after reading this article:http://batteryuniversity.com/parttwo-34.htm). That would really suck--invest lots of $ and only get 2 yrs of practical use when I expected 8-10! Anybody w/li-ion have experience to share there?
My goals are these... The Ghia is roughly 2000 lbs curb weight before conversion. I'd like to see at least 50 miles per charge and 0-60 times not more than 9 sec. So I want a real, highway-capable commuter but I clearly won't be chasing down any Teslas.
Thanks for any ideas or comments.
Greg
#2 ·
Greg,
If it's any consolation, you are definately not alone. The dreaded battery decision is what is frustrating and delaying many EVers I expect. I'll be doing a similar project with similar expectations (Miata). I won't need quite the acceleration you're looking for.
Your lucky in that your daily commute is short enough that you could use lead without adding tremendous weight that would require suspension and brake upgrades.
I really want to convince myself that lithium is the way to go and perhaps even a good investment vs. lead. The worry is as you suggest, what if they don't last 8-10 years?? It raises the questions; should I start with lead, then switch? should I delay for a couple of years till lithium or a successor is proven?
No one knows the true long term performance of the new chemistries (calendar life, cycles, DOD issues...). Plus, it seems pretty unlikely that there will be any kind of meaningful warranttee, at least for a bargain priced cell.
Sorry I don't have a useful suggestion or solution! Where do we go from here? I keep hoping that a large group buy will be arranged that will address the issues of cost, reputable supplier and warranttee. I know what I want, I just can't bring myself to spend $20+K on batteries!
Rob
#3 ·
You can expect lithium batteries to last as long as they do in your cell phone, which is only a few years. Not suitable, in my opinion, for EV use except high-end applications where life expectancy is not a serious factor.
NiMH technology in EV-size packs may become available to the public if and when controlling patents eventually expire, or not, since, as a suppressed technology, NiMH would be difficult to obtain in any event, as it is now, unless something better came out by then, but that is in the future and this is now.
So for now, most EVers will have to make do with lead. Which is ok. It is heavy, but it is cheap. You get relatively lots of power for the money. Yes, the weight brings up chassis, suspension and brake issues, but they are solvable in a way that still makes a cost-effective, useful car more than possible.
#4 ·
Thanks for the replies, ya'll.
I've seen examples online of people who've converted Ghias/Bugs who've used 10 12-volt batteries of various manufacture. Probably my likely scenario. That'd give me 120v to play with.
I will also investigate front-ending a lead-cell power pack with some super-capacitors to give me a few seconds or so of "turbo-boost" to get my off-the-line acceleration and still enjoy the cost benefit of lead cells.
Does anyone know how I can learn what chassis or suspension improvements may have to be made to a Ghia to handle 10 batteries? I suppose it depends on what batteries I choose, but heavy-duty deep-cycle models could add 700-800lbs to the little car. I can easily put heavy-duty adjustable shocks on the car, but what else should I consider?
Greg
#5 ·
It's hard to compare Lithium in a Cellphone as compared to them in an EV. You'd thave to figure out how many cycles that Cellphone is racking up during those few years of use.
We are on the last leg stage of the LiFePO4 upgrade of the Dallas/Ft.Worth's Electric Auto Association president's Fiero. It made it's first 25 mile round trip voyage to the 2008 North American Solar Challenge race kickoff in Plano, Texas this weekend.
The car performed VERY well, both in off the line performance, no bottoming out at railroad crossings, and the voltage only dropped a couple of volts overall once the initial surface charge leveled out to the pack's nominal voltage.
The bussbars will be replaced to handle the current better, as some were warm to the touch, but not to hot to keep a finger on them. I know John's one of those that will not let that slide, and is looking now for heavy guage stranded flat braided straps.
You can see his conversion in the Fiero Upgrade photo set at:
www.flickr.com/mbarkley/sets
But especially, check out the videos/photos of the kid's cars in the 2008 North American Solar Challenge as well in that photo set. Those kids worked hard on those cars.
