Proprietary batteries
Many portable consumer electronics contain proprietary, often lithium-based batteries. These batteries last only about 500 cycles before losing large amounts of their capacity. Rechargeable lithium batteries always contain integrated circuits (IC); they are required because of the above average risk of fire or explosion the batteries have when improperly charged. The IC keeps track of statistics of the battery to determine the current full charge point for the battery. A manufacturer can set the algorithms of the IC to be ultra conservative or time/cycle based, rather than based around the physical properties of the battery cells; this artificially limits the life of the battery. The IC will not permit the device to charge the battery any more than the IC dictates. Production of these batteries is usually stopped at around the same time the product is discontinued,[citation needed] therefore rendering the product worthless once the batteries start to wear out. Some people will reset the ICs in the battery pack, and obtain almost their original runtime on the battery (minus the natural decay the battery cells),[citation needed] only to have to do it again in the future because the IC ran down the limit.
While battery packs can be rebuilt and fitted with new cells,[6] this is either too costly or too time consuming for most consumers.
