urrently I'm focusing on the AzureDynamics AC55 motor, but there are some data which are puzzling me a bit.
Electroauto displays this motor for 78Kw peak at 8000 rpm's (34 cont.), while Azure Dynamics data sheets calls for only 59kw peak (25 cont.).
where is the truth?
Also, azure dynamics suggest this motor for direct drive applications as it is a low-speed design for a 3-5:1 ratio.
May I use it with a manual 5 gears transmission or is it better to remove everything?
any help?
thanks.
where is the truth?
any help?
thanks.
